BC Racing Coilovers Help
    Heys guys I just installed the BC coilovers (BR SERIES), and the rear is making squeaky sounds. When i bounce it up and down, and also over humps.
    I have tighten everything including the upper mounts 2 rings (It is tighten with a breaker bar, so it doesn't move) and the lower ring (which i adjusted to get the height). Also tightened the 2 tops nuts too, on both coilovers
    Here is a diagram of the coilover (Same concept for the rear):
    http://www.bcracing-na.com/HEIGHTADJUSTMENT.htm
    Car: Dc5r
    happened to me as well
    i think cause its new the springs are squeking
    Blaze Orange
      u didnt grease up all the rubber mounts by the sounds of it...but then i just looked at diagram lol theres no rubbers haha
        Is this normal? Does it die down in a couple of weeks?
        As my one squeaks pretty loud, and i think its not normal.
        I didnt use grease. If i did, where should i apply the grease? where the spring and the shock meet at both ends?
          i noticed the squeak coming out of my driveway as soon as i installed it, spent 20 minutes trying to find out whats going on.
          slept on it for like 2 weeks tried to find the sound again, couldnt hear nothing.
          Blaze Orange
            i corrected what i said lol
              Ok ill get the wheels alligned and report back in 2 weeks..Hopefully it will die down!
