Hey guys.. Just got back from overseas yesterday. Was away for one month and i went to start the car and my batt was dead. Jump started it and it started. i was letting it warm up until my revs started jumping around.. between 1 - 2 rpm. Felt like someone was in the car reving n reving. I turned the car off and started it again, idle'd fine then the revs started going crazy again. I was going to take it for a drive but was too scared that something would happend to it. I Unplugged the battery to reset the ecu. Would this fix the problem? Was also told that maybe my Throttle Body could be dirty? .. going to check the oil incase its low but i highly doubt that would be the case. Also the car is pretty much on an empty tank but id put 5ltrs in it so i guess that should be ok.
Any inputs would be much appreciated
.. thanks guys.
