Adjusting DC5 headlights
    Hey guys.. Was driving in front of my car last night n fuck! My hids are blinding.. Any tips on how to adjust it?... I havnt had a look yet, but is t really that easy to park up against a wall n use a screwdriver to adjust it? The passenger side looks awkward with te battery there... How hard is this tweak?
    tweaking is easy.. the battery doesnt block your passage to the adjuster. it should be accessible using long screw driver from the top of the headlight frame rearside
    The pic below is tweaking the light for a DC2, but for DC5, it should be similar. In fact, you can see a writing on top of the headlight something like this "U<--->D".
    U means up and D means down.
    - Project R -
      Cheers, any more insight? i like to know anything and everythign before i attempt anything!
        instead of using a long screwdriver use a socket, its much faster.
        also make sure you are facing a wall to project the light onto, or else you may barely notice the movement and end up with misaligned headlights
