I dunno about spoon calipers but the pad moves slightly. When u reverse and touch the brake the pad clicks back slightly then once you drive forward the pad clicks forward again....
Yes, the pad does move around a bit. Hence when you turn your steering wheel, you'd hear the pads very distinctively. Isolated characteristic to the twin-pot setup only. No such character on the monoblock.
thanks for the info all good the thing is i dont get it why the mono does do it ??
Yes, design of the brake pad holder - The black Nissin square piece is different on the monoblock and twin block. It isn't an issue however, otherwise Spoon would've revised the design if necessary.
