Disclaimer: The following is provided as a GUIDE ONLY, and neither myself nor ClubITR take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
step 1: obtain 1mm aluminium sheet (I got 90mm by 60mm)
step 2: obtain 20 x M3x20mm countersunk hex screws and 20 x M3 x 10mm button head hex screws
step 3: obtain 10mm x 10mm x 1000mm of aluminium angle
step 4: obtain some 6mm thick Perspex
step 5: obtain some seriously good double sided tape (I had some 3M stuff)
step 6: remove sunroof
it weighs 15.3kg all up
step 7: place aluminium sheet over sunroof hole and using a marker pen, trace an outline of the hole on the underside of the aluminium sheet
step 8: using a jigsaw, cut the aluminium sheet to size and dress edges (this takes a while to get perfect, I used a metal file and several grades of sandpaper)
step 9: cut aluminium angle into 10mm sections (called L-tabs):
[IMG]
[/IMG]
drill 3mm hole in each L-tab:
line up the each L-tab with the groove around the sunroof hole, kinda where the spot welds are, and drill 3mm holes in the steel drapes around the sunroof hole, 5 on each side and 8 on the leading edge:
install the L-tabs
[IMG]
install the L-tabs
