Fitting Mugen Front Strut bar for DC5
    Has anyone here fitted the Mugen Front Strut bar on their DC5 before?
    Is it the same bar for all DC5's? (R / S / Lux)?
    Got one here in front of me and it looks like the mounting holes are off by 5mm or so on 1 side of the bar
    Team Misplaced CT9A Owner #010
    Same bar for all. Will fit without removal of the OEM bar on the 02-04 but requires removal of the OEM strut bar on 05-06.
    It is a tight fit, particularly if you have aftermarket coilovers that have longer studs on the front. Just put some strength into it or jack the front of the car up slightly until the 3 studs on the top of the strut start to drop through the holes a little, this should make it easier to get on.
      What the above guy said.
        Yep,
        It's a tight fit....
        Like Tom said, get one side in, then PUSH HARD....lol
