Had a quick search but didn't find anything thorough on these forums apart from the below thread.
http://forum.clubitr.com.au/showthre...ghlight=airbag
This thread was useful but would be awesome if someone can do a quick write up on exactly what they did to get around the SRS light that comes on when you remove the stock seats that have the side airbags in them.
I found these two threads on ClubRSX. The first seems simpler than the second and does not require the removal of the airbag from the seat for any reason what so ever.
http://forums.clubrsx.com/showthread.php?t=308198
http://forums.clubrsx.com/showthread...ermarket+seats
Another option would be to buy the airbag module from a dc5r but that is pretty costly compared to the other methods. There was mention of a resistor that could be used, what ohms and where would you plug it in?
If anyone has done it, could you post up saying which method you used. Pictures would be awesome also!
Thanks in advance
Thanks in advance
