strted the honda this afternoon and it was idling around 600 rpm and sloweelly creeped up to 800 area where it normaly sits..when i give the throttle a blip as the revs drops down it goes down to as low as 450rpm ...sometimes it picks back up and sometimes it actually conks out...what u reken it is ? i got a feelin its the iacv but i wanna know if u guys have had the same problem before becuase i dont wanna be pulling it down for no reason.... i was gunna plug the scan tool in but i cant find the dianosis plug!! i got a bad feeling it might be flash code ?
idle problem
just had another look...i had a listen at the exhaust and it sounds like its missing pretty badi did my tappets today so i thought maybe i might have over adjusted them...but it did the same thing the other day and i flicked the lil electronic thing directly on top of the TB and it came good for 3 days... but now its back! and flicking it aint fixing it... what is that thing on top of the TB ? is it a Map Sensor ?
Originally posted by jppisbest View Postisn't that the TPS? throttle positioning sensor? correct me if i'm wrong
Originally posted by DC2RKID View Postjust crossed the brown and black wire over and got a code number 54 out which is a Crankshaft Speed Fluctuation Sensor...what the hell is that lol and where the hell is that
step 1. register on site
step 2. download - Acura Integra (98-01) Service Manual (57.76mb PDF)
step 3. look up code 54 and trouble shoot.
but i suspect you stuffed up the valve clearances - did you re-do them?
what clearance did you use?
where did you measure it?... retired/
not sure if this would be the cause but could be, try disconnecting your battery for a certain amount of time and reconnecting it, take you car for a spin and see if your ecu is still registering this fault, if it's not then you'll know this is out of the question. like mine, i was doing some other stuff to my car so the battery terminals were disconnected, afterwards the ecu didn't register anything
