got a new clutch and friction point is really high (literally right at the top) is there a way to adjust this???? please help it's quite annoying, i constantly over rev
DC2R can someone tell me how to adjust the friction point?!?!
what clutch did u get installed?
when i got my exedy sports organic put in, the biting point was much higher than what i was used to in my stock clutch... and i bled it a few times after too lol! but after asking around, apparently its quite normal.
Also drove another dc2 with the same setup, and his biting point was identical.
You can adjust the clutch pedal though... i adjusted mine a couple mm to remove the "slack" or free play when fully disengaged... so it doesnt seem so "high".
Originally posted by tinkerbell View Postthe point moves 'up' as there is more meat on the clutch,
you replaced a worn-out one right?
i've also adjusted it from the pedal too but still feels as though there's not much difference, just doesn't feel right lol
