Coilover spring loose?
    When I jacked up the car to lower it I noticed that the spring on my coilovers is quite loose on the left rear side compared to the right rear, it was moving around more easily and had alot more room when compared to the right side. I measured the height of the coilover and found they were relatively the same height maybe 1 or 2mm off. When I dropped the car back down the springs compressed normally and it went over bumps and all that just fine, basically is there any need to be concerned?
    Do you have adjustable perches? ie You really want them to be sitting tight (not compressed, just firmly held in place) -- Guessing the issues you could run into would be in droop? (ie. Rebound past ride height).. ?
