So i got my alignment today and found that the caster was off. i had positive 2.xx degrees at the right front wheel (i cant remember exact value) and negative 1.xx degrees at the left front wheel. The difference was nearly 3 degrees and my steering wheel sits tilted to the right.
When i had my stock suspension on my dc5R it was fine but after i installed a set of buddyclub N+ this occurred.
Any possible causes?
WAsuspension suggested i get a caster kit to fix the problem. Is that really necessary... or is there other ways i can correct this.
bansai!
