Guys, any of you might know the angle (valve lift) of the original camshaft that's in our AUDM DC5R's motor?
DC5R Camshaft
bump!
TODA, K20A Spec C Profile Camshaft
TODA, K20A Up Rated Valve Springs
TODA, K20A Heavy Duty Chain Tensioner
Planning to order these as the currency is quite good, is there any i need to be aware of moving on and installing stuff like cams on my car? I will be installing Hondata, KPro at the same time while installing these parts.
It is about $900 for the pair of camshaft, so i think it is quite a good price. What you guys think?
Spec C is still drivable for street use, right? Adrian didn't recommend me to go any higher with just a stock K20 block.
Bit of background of my car: gruppe m intake, rbc IM, toda heaader + cat, greddy catback.Last edited by Tiu; 11-11-09, 03:38 PM.'03 Integra DC5 Type R
you also need a headgasket, maybe 'want' ARP head studs... since you seem to be keen to spend money...Originally posted by Tiu View Postbump!
how is your breather system looking?... retired/
what's the ARP head studs do for me?Originally posted by tinkerbell View Postyou also need a headgasket, maybe 'want' ARP head studs... since you seem to be keen to spend money...
what's breather system (i'm noob), is that the hose that connects to the right side of the head and then connects to the gruppe m intake?'03 Integra DC5 Type R
nope, not interested in that so i never really gone and done it.Originally posted by TypeSexy View Posthave you gone to the 1/4 mile? if so whats your time?'03 Integra DC5 Type R
re you specific question, I can only comment from the point of view of spec B's in a B18. The off-vtec lobes are much higher, and that shows in a more difficult idle, quite a bit more power, and much worse fuel consumption. The vtec lobes are convenyially higher etc. The spec C have more on vtec. You will need the springs, and the after market ecu set-up. The standard ecu just can't cope.
Driveability on the street is still very good - my only problem is low idle when mid warm-up. Thats probably the iavc.
I note you don't have adjustable cam gears - I'd say not really necessary right now.
If you use the car daily and do a lot of miles the fuel consumption will kill you. If thats not a problem, do it. The power increase is great.
at the moment with my mugen n1 ecu, i'm getting 400km & about 41xkm max
so i hope that the kpro will work abit better than the mugen n1 ecu, anything above 400km then i'll be happy
i spoke to adrian from TODA yesterday, he advised me to get the TODA, K20A VTC Killer Free Adjusting Cam Sprocket for the exhaust side only as well.
Originally posted by Ian aka anjin View Postre you specific question, I can only comment from the point of view of spec B's in a B18. The off-vtec lobes are much higher, and that shows in a more difficult idle, quite a bit more power, and much worse fuel consumption. The vtec lobes are convenyially higher etc. The spec C have more on vtec. You will need the springs, and the after market ecu set-up. The standard ecu just can't cope.
If you use the car daily and do a lot of miles the fuel consumption will kill you. If thats not a problem, do it. The power increase is great.'03 Integra DC5 Type R
grrray - maybe you need a tune up?
or a ecu reset?
that is terrible fuel economy for a stock car and indicates you have a major problem... or maybe you refill before the fuel light comes on?
here is a thread we prepared earlier: http://forum.clubitr.com.au/showthre...el+consumption... retired/
I have finally placed the order the follow
so excited!! it should arrive in about month's time. However, i won't be install the stuff anytime soon as i still have to save up for a Hondata, KPro.
TODA, K20A VTC Killer Free Adjusting Cam Sprocket (Exhaust only)
Also i've ordered myself a Mugen, Engine Mount as my oem ones are starting to go as well.
Ohh
i think it was all quite reasonably priced, all these parts together costed me under $2000.
