Hey guys,
just need a bit of advice.
Was servicing on the car on the weekend, oil, tranny oil n stuff.
While i had the car jacked up, i realised the front left wheel had abit of play in it. about 2-3mm of it.
I rotated the wheel a few times, and i could hear what sounded like a loose bearing clicking inside after each 360 rotation.
I'm guessing my wheel bearing needs to be replaced. damn alma rd...
i've checked the other 3 corners, and they are fine.
so question is, should i get the front pair of bearings done together?
since i'm guessing that if one goes... the other will soon follow?
or should i only tend to the problem corner?
thanks
thanks
