ey guys does anyone know the clearances in which the tappets have to be on a b18 engine and also any idea where to buy the special tool to use on them as i heard the b18 is a bit of a pain
B18C7 Tappet Clearance
Originally posted by DC2RKID View Postey guys does anyone know the clearances in which the tappets have to be on a b18 engine and also any idea where to buy the special tool to use on them as i heard the b18 is a bit of a pain
Quote:
Attached FilesLast edited by tinkerbell; 30-07-09, 04:55 PM.... retired/
I did mine the other day - It's not hard with a 10mm deep socket, I just found that I'd have to tighten and re-check a few times to make sure the adjuster screw didn't tighten with the nut.
After I got the hang of it, it was all good. I used 0.18 for intake and 0.2 for exhaust. A few were a bit tight from my previous attempt, causing a random misfire.
