paranoya? rear camber kit
This topic is closed.
    just put on camber kit guys,
    BUT
    is the kit supposed to be SUPER tight fit to put on! i got the Buddyclub rear camber kit.
    i put it on fully negative camber as much as possible! lol.. so the camber kit is shorten a fair bit...
    but im scared now.. will the camber kit snap? cos it required a bit of force to put it on ay! mm
    feeeddback please!
    Where is it 'super tight'? In the adjustment? Nothing EVER should be put on or adjusted with 'force'.
    Deano.
      nar just the whole rear camber kit is required some force to put on, it didnt just slip in...
      the bolts where fine, just putting it in? and lining it up was difficult as!
        yes, they can snap, so be super careful if you are unsure if it is on right...
          took it to a suspension shop to adjust the camber and everything right.. no dramas at all..
