DC5 Oil Cooler hose size?
    What is the recommended hose size for Oil Cooler for DC5
    should i use Dash 10 or 8??
    does it make a difference?
    Nankangs, Better than Your-Mums-Cans
    * Please note, I hate Nankangs.
    i recommend dash 10, but not sure if it makes a difference...
      Paul, I spoke to Ben and says just use dash 10.
      It's just a slightly larger hose size that lets you flow more hot oil to the cooler.
      A larger volume of oil will be away from the engine and in the larger hose if that makes any sense.
      Most ppl use dash 10 if that helps. Dash 8 will probably give you a bit more oil pressure though.
