Hi guys;
I have this issue with my clutch that it vibrates whilst being depressed or released.
It is hard to describe, but as the pedal travel should be normal and consistant, it sometimes does this under hard braking or when braking over bumps and ABS kicks in.
Instead of having consistant feel thorughout the pedal travel; it sometimes becomes rough or light.
This has come about since I did a clutch fluid flush from the slave cylinder.
I replaced the clutch fluid with Motul RBF600. I did the flush correctly and never let the resovoir go to minimum, continually topping it up.
Any ideas on the cause of the problem or how to rectify?
Chris.
Chris.
