DC2R owners - What size semi slicks are you running?
    Hi Guys
    Currently looking at semi slicks - Just wondering what sizes you guys are running on your DC2R with 16x7" rims.
    I looked at the TOYO R888 range, but it looks like they don't come in 205/16/45 or 215/16/45
    Just wondering if the DC2R with 16x7" rims can run 225/16/45 tyres, or would they be too wide to fit?
    What other brands of Semi slicks are you guys running and what sizes? I think the RE55 would come in 215/16/45 tho - how are these tyres like and are they a lot more expensive compared to the TOYO R888?
    Thanks for your help!
    Daniel
    Last edited by apparition; 08-03-09, 06:15 PM. Reason: Forgot to add some more details.
    225/45R16 for the front is ok I guess
    I run 225/50R15 front and 195/55R15 rear...with 15x7 rims
    Honda Integra DC2R natural aspired K20A
    2010 CAMS Supersprint (NSW) Type 3B champion |EC: 1:46.9280|WP: 1:07.694|Winton: 1:38.614
      I'm running RE55's 215/45/16 all round i had to roll all my guards considering the height of my car. they were close to 400 a corner from memory
      I can't compare to any other semi since I've never driven on any other semi's before. But I only hear good things about RE55's!
      When I was looking for semi's for anything in the 215/45/16 size only RE55's came in that size so it's going to be hard to find 215/45/16 I think. Maybe Dunlop D01J came in that size.
        Thanks for the replies!
        Having some issues looking for Semis to fit 16x7 rims for a DC2R!
        Would R888's 205/55/16 be okay to run on a DC2R or not?
        My other option is to fit 205/50/15 on my stock DC2R 15" rims - you guys think that's a better idea?
          205/50R15's - i have run:
          Toyo Proxis RA1's
          Toyo Proxis R888's
          Bridgestone RE55s
          205/50R16 - i have run:
          Dunlop D01J's
          these rubbed on the rear arches and never tracked with them on...
            100% better idea
              195/55/15 - TOYO R888
              Stock rims
              "Power is nothing without control" - Peter Tyson (Pirelli)
              http://thethrillofdriving.blogspot.com/
                Dunlop D01J's
                I too have 205/50R16 Kumho V70a but I got no probs at all
                is that because Dunlops are bigger block?
                  your car will be jacked up by almost 2cm compare to stock
                  if you want same size all around try 215/45R16
                    they are called "205" but are actually: 215mm wide
                    see: http://www.garysmotorsporttyres.com....anges.cfm?id=3
                    dunno how wide the kuhmos are?
                      Im running 195/55/15 on 15x6.5
                      Tom says: "Now remember kids, offsets are like women... they are best in their teens."
                        Toyo makes a R888 in 195/50R16 size.
                        Proudly no longer a member of any WA based Honda forums.
                          I need new street tyres atm, does the 205/55/15 fit the stock ITR rim ok?
                          The guy at my local bridgestone place said that the OD (=overall diameter) should be no more than 13mm than the stock tyre diameter, the 205 is 14mm above the stock OD. He said it should be fine and i agreed that 1mm surely couldn't make that much difference.
                          What are your experiences? and is it worth having a lower profile tyre and a bigger footprint on the road? What are the pro's/cons?
                            What is the stock tyre size for a DC2R? Isn't it 195/55R15? If that is the case the 205 is 9mm smaller than stock and should be fine as long as the load rating is sufficient.
                              I just checked the bridgestone website,
                              the 195 = OD of 596
                              the 205 = OD of 608
                              Making the difference only 12mm's. Looks like the guy made a miscalculation.
                              http://www.bridgestone.com.au/tyres/...Adrenalin.aspx
                              Who has the 205's and has any feedback on wether its worth getting them over the 195's?
