If you thought JDM Brembo conversion required the whole DC5R driveline, you are sadly mistaken!
It didn't make sense to me why people had to change the entire knuckle, LCA, driveshafts etc. to do this. Then I heard that the problem was simply that the Brembo calipers centre line was some 7.5mm further out than ADM DC5/EP3/FN2/AP1 calipers. If that was all, how hard can it be? I sourced some DC5R Brembos for a decent price, and bolted it up. The standard brake lines and caliper bolts fitted with no hassle at all! and surely enough the ADM DC5/EP3/FN2 rotors were sitting too far inside by 7.5mm. At first I fabricated some 7.5mm spacers and that fitted fine before I realised that S2000 rotors have exactly 7.5mm less offset than ADM DC5/EP3/FN2 rotors.
So out I go to source some cheap S2000 rotors. When they came I trial fitted them on some spare DC5 knuckles and woohoo perfect fit, then I bolted it them up to my FN2, another perfect fit! The only downside to this install is you need quite an agressive offset wheel to clear the Brembo Caliper, I'm using 18*7.5 +30 and 17*8 +38 wheels to clear the caliper.
As for how they feel? to be honest they on day to day basis, they feel like OEM ahahaha. The Brake pad change made all the difference. On the track its different though, brake pads dont fade as easily and pedal feel is more responsive under braking, but it's still mostly feels like OEM calipers!
