Hi Guys,
Just wandering if you can give a comment which wheel spec that would be
most suitable for my Type-R EP3 to clear my Spoon caliper.
The original wheel spec on my EP3 is 17x7 +45. And currently I'm using
H&R 5mm wheel spacer to clear the Spoon caliper.
There are 3 options of wheel that I like:
1. TE37 = 17x7.5 +40
2. P1 QF = 17x8 +35
3. CE28N = 17x7.5 +33
I have checked these specs against my original Type-R wheel at
http://www.1010tires.com/WheelOffsetCalculator.asp
According to the calculator, the 1st and 2nd options give me inner clearance
1mm LESS and 3mm LESS respectively. The only option that gives me inner clearance 6mm MORE is the CE28N spec.
Isn't it wheel width is irrelevant to clear my Spoon caliper as long as the offset is less than the original +45 offset ?
Or the Wheel Offset Calculator is right which means, CE28N is the only option that can clear my Spoon caliper?
Hope to hear your comments. Thank you!
2. P1 QF = 17x8 +35
