Hi all,
I have recently sort of learnt what RCA's do, and in theory I think they will help my bumpsteer / skipping across corners I get at higher speeds on bumpier surfaces.
I know they are a big thing for the DC5R, EP3R guys for McPherson strut. However, who is using these on DC2/EG etc. Did they make a noticable difference? Are they worth it?
It seems (maybe?) that some are different lengths... what difference would this make?
Below is some info on RCA's...
stolen from JDMST
RCAs - Roll Center Adjusters, also called "Bump Steer Spacers" - are designed to eliminate "bump steer".
Bump steer is when your wheels steer themselves without input from the steering wheel. This undesirable steering is caused by bumps in the road or track interacting with improper length or angle of your suspension and steering linkages. You can often feel the bump steer as a jerk in the steering wheel to the right or left when you go over a bump or uneven pavement.
When you lower a car it changes the geometry of the steering control arms resulting in bump steer. The RCAs return the lower control arms to their correct geometry and help eliminate this bump steer problem.
Please note, if you have an exessivly lowered or stiffly sprung car, these will have less of an effect.
Source
stolen from JDMST
Source
