Hi Guys & girls,
At the moment, I am running the AKOM setup, inverted tie rod ends with the steering arm bracket. The arms look pretty straight and parallel atm. I have had a wheel alignment done recently at Fulcrum Suspensions. Very minimal bump steer if any. Current settings the car is running:
Front Axel:
Castor L = 1.92, R = 2.12
Camber L = -1.79, R = -2.01
Toe L = +0.1mm, R = +0.01mm
Rear Axel:
Camber L = -0.87, R = -0.99
Toe L = +0.0mm, R = -0.1mm
I am lowered on Tein Flex with approximately 1 finger gap on all corners and running Brembos at the front only, so has JDM LCA's and aftermarket front swaybar.
However, not entirely happy with the way the car is running at the moment. There seems to be a bit too much play with the steering, and steering wheel itself is not 100% straight (has slight bias to the right). Fulcrum advised me that the bushes were starting to wear out at the front. Does anyone know what bushes these are and if they would help? Im thinking of running slight toe in as well for more straight line stability as I do alot of highway driving.
At this stage, what are my options for more steering wheel stability (less play). Would going back to stock Tie Rod ends be an option? Any thoughts/recommendations highly welcomed and appreciated. I'll add some pics later on..
Front Axel:
Rear Axel:
