DC5: topfuel tie rod end with RSD
    i got a set of buddyclub racing spec coilover on my dc5r, and today try to put the topfuel tie rod end
    my mechanic said yes, the topfuel tie rod end can be fit on, but he wont do that , coz it s dangerous...the wheel will tod out all the way....
    i dun really understand why. so before i go the the workshop, just come up and ask on it , c if anyone got experience....
    cheers
    Project: DC5R>>S2000>>NSX
    How much negative camber are you running and how low is your car? These are things to consider. The top fuel tie rod ends are most likely shorter than the stock ends to allow more camber to be used before the end of toe adjustment is reached.
      Might find some answers here
      http://forum.clubitr.com.au/showthread.php?t=4359
      and
      http://forum.clubitr.com.au/showthre...ht=tie+rod+end
        thx mate, very useful info
        and just wanna say, i also using the akom steering brace on my car...
        i ll go the the workshop after i finish the work , and will get more info back
          need to know exactly what the fitter thinks the issue is...
          lucky this has been covered so much, with more info from your mechanic, the DC5 guru's shld be able to sort it
