Hey guys, i can't afford a nice set of coilovers yet so with the koni yellows in mind i want to match a new spring that'll drop it a bit more, i'm pretty sure it would be within an inch lower than standard atm and i want a little bit more, also keeping in mind my toda extractors and power getter pipe that i want to keep off the road, cheers, and it will be tracked also... cheers guys
What springs to match with koni yellows?
How about a Ground Control coilover/sleeve with springs LINK. They let you pick whatever spring rates you want and adjust the height too. Guys on Honda-tech seem to rate them reasonably highly.
EDIT: Also if you decide to go that route and need to decide on spring rates I found an interesting thread discussing spring rates: LINKLast edited by ChargeR; 16-07-08, 09:39 PM.
If you are running koni yellows there a perches.. so each height is different..Originally posted by Absolut R View Posthmm interesting! have you got any pics of it when they were on??
I actually had them on my civic.. adjusted it accordingly
ahahah look how many dead coils are on them to keep the springs captive.. a sign of quality
