DC2R - Spoon Brakes, Stock Wheels & Spacers
    Has anyone had experience with this combo on the track?
    I'm concerned if there is enough thread for the nuts to go back on tightly..
    Cheers!
    get extended wheel studs, this is major stuff!
    how much thread is actually available?
      Felix you got the H&R kit put it on if your worried.
      I ran my capliers and spacers as it is had no drama's on the track twice. But to be on the safe side put the extended studs on bro
        3MM spacers off Ebay do the trick.
        http://cgi.ebay.com.au/MAG-WHEEL-SPA...QQcmdZViewItem
        You'll most likely find spacers/washers behind the calipers to space them out (people do this for even pad wear). Take them off.. and your Caliper will move in like 2 mill. Use stock nuts, and these 3mm spacers... and they will fit easily, with a 1 - 1.5 mm clearance. Check your nuts after each session. They were fine on mine.
        Originally posted by ChargeR
          I haven't trial fitted it yet so I'm not exactly sure how much thread is left.. the spacer is approximately 5mm thick from memory.
          Yeah I was going to put the extended studs on (which are only 3-4mm longer lol) but I was advised that i would need new bearings because you can't just knock out the standard studs..
          Oh I've got those washers.. they come standard with the Spoon brake kit right? Did you still need to use a spacer after you put on those washers because I remember you said you got the stock rims on without a spacer.
            No... you take the washes out, and they'll move the caliper IN... I guess they must come with the brake kit.
            I think we got the wheel on without a spacer... forgot now though. It wasn't enough clearance to be safe.. like less than half a mm. So I used a 3mm spacer to be safe. You can get the extended wheel studs... but IMO are not needed for 3mm.
