can anyone reccommend any good brands? im going to get my car serviced soon from hannys but not sure what oil would be the best to use as it's my first DC2R service.
also whenever going into first gear and sometimes second.. it doesn't go in properly.. goes in like half way.. then when you try to put it into gear properly.. the clutch starts to grind (possibly cause i accidently hit the accelerator thinking it's in properly)
just wondering whether this was a problem because of the lack of gear oil (i was told i needed to top it up by the previous owner) or a problem with my actual gearbox.
Thanks in advance.
Thanks in advance.
for the gearbox to be taken out and fixed with all bearings replaced, with 5th and reverse gear newly replaced.
