Does anyone else have the same problem? the passanger window is very slow to wind up...
sluggish passenger electric window (DC2)
Tried taking the door apart to investigate? I knew this was a common problem with Nissans, but never known any late model Hondas to have this problem."No Matter that you have a PhD and have read all of Henry James twice. If you still persist in writing, "Good food at it's best", you deserve to be struck by lightning, hacked up on the spot and buried in an unmarked grave" (Truss, 2003, p.44).
slow windows
haha its not just an integra problem - it happens cars like civics aswell !! ripp off your door trims - grab your silicon spray and put that flexible extension tube on it. shove the tube through the holes in the door and then sprayyy your day awayyyOriginally posted by mofo View Postmy first type r i noticed that the passenger window was alot slower then the driver window...thought it was the window lifter being weak.
now with my next type r i have the same issue..
so i think its just a type r or integra common OEM issue ahahaha
check the rubber...i had this problem before, when the window is closing it's not going up straight and the rubber was pushed out as the window is going up. had to take off the trims align the window and problem solved
z10 says:
z10 says:
