Below are three dyno printouts as follows
Initial Tune - Custom Intake Manifold (there was also a dyno run at toda with the JDM Intake manifold back on the car yet untuned and the car made 151.x kW but was running lean up top hence the touch up tune below - dyno 2)
Touch up tune (which was done from scratch for some reason??
)after changing from Custom Intake Manifold back to JDM Intake Manifold 29/7/06
Dyno Comp - No change to car from previous dyno run - For you info it translates to 143.1kW
So who can pick the differences?
