has any of you guys made these for your car? i have been advised to make some to help with brake cooling..any piccies / explanation would be much appreciated, esp for dc2r. thnx
brake cooling ducts
I'm looking at options to feed air from front bar to brakes right now. I run CAI and oil cooler which restrict air flow to brakes. Overcooked HC Plus (800c+)Originally posted by Jingers View Postdc5rs have this from stock so u prolly wont hear much from dc5r owners...
there are those orange pippings u can buy which are high temperture proof. That should do the trick
pads after 6 laps at WP yesterday. Should be able to draw it it from space between radiator and front bar. I've removed AC from my car.
mm yes well ive cracked my zeal streight6 rotors even though i always do cooldown laps so similarly i need to get more cool air to the brakes..
piccies anyone of some good setups? as i hear i will need to cut the plastic inner guard thingy and i would be more comfortable doing this not being the 'test guinea pig'.
ur cai im guessing is Injen? I am not completely aware of how the injen set up is. Does it block the air for the brake ducts? Maybe ill get gruppeM after all lolOriginally posted by m0nty View PostI'm looking at options to feed air from front bar to brakes right now. I run CAI and oil cooler which restrict air flow to brakes. Overcooked HC Plus (800c+)
pads after 6 laps at WP yesterday. Should be able to draw it it from space between radiator and front bar. I've removed AC from my car.sigpicCurrent holder of the Win folder.
Sure is. I'm looking at going to J's Racing intake once car is off road so I can work on getting better ventilation to the brakes.Originally posted by Didz View Postur cai im guessing is Injen? I am not completely aware of how the injen set up is. Does it block the air for the brake ducts? Maybe ill get gruppeM after all lol
