disabling SRS light
    disabling SRS light
    ive just got myself a steering wheel without airbag and wondering if anyone here knows how to get rid of the SRS light tat comes on... thx!!
    http://kingtan.com.au
    you need a yellow plug with from memory a 2ohm resister in it
    jdmyard or topone can get you these from honda, they got me one
    z10 says:
    z10 says:
      wow... cool... thanks for the quick response eddie...
        btw... how much do they cost??? and do i just install it myself or best to get dedy to do it for me... :\
          around $30 buks from memory
          but if you already put on the steering wheel and the srs light is on already, you need a computer to disable the light even after you put in the resistor plug....is motor racing disables the light with a computer for me before
          z10 says:
          z10 says:
            you can install this yourself...just make sure the battery is unplugged....take off steering wheel then put the resistor plug in then put on your after market steering wheel
            z10 says:
            z10 says:
              damn... dedy installed the resister for me and the light is still on... damn...
                alrighty!! managed to get it fixed!!!
                  You wouldn't happen to know the part number for that would you?
                    how? what happened?
                      im guessing he plugged the computer in and disabled the warning??? indy did that for be a long time ago
                      z10 says:
                      z10 says:
                        yeah... disable it from the ecu... but if u have an aftermarket ecu... you will need a chip to bypass it... the chip is plugged into the steering wheel wires...
                          why not just remove the bulb?
                            dc2 would be easy to remove....dc5 adn jazz have led bulbs so makes it harder
                            z10 says:
                            z10 says:
                              icic!!
