Hi guys, how do u know if ur engine needs a valve adjustment? i have a ticking sound coming from the engine (at least that where it soundsl ike its coming from) and i dont know if its a normal thing or what
You should be able to hear the engine ticking ever so slightly...
This will be your injectors opening and closing...
If your valves are noisier than your injectors they might need an adjustment...
If you are unsure - just open up the bonnet with the engine running and stick you head as close as you can to the top of the engine (called the "rocker cover") and listen...
Then move your head to wards the intake manifold where the 4 injectors are...
This will allow you to assess the area where the ticking comes from... however - you should NOT be able to hear the injectors from inside the car
Did you do any mods? If you have I/H/E ... I have found with exhaust efficiency, the tapping gets louder... If I install my silencer ... everything goes quiet.
