*HELP!* 'auto' driver side power window not working
    gday pplz! i vaguely remember there was a thread on this but i can't find it now, can't remember if it was here or on clubrsx? can someone please help me fix this, the window still goes up and down, but the auto function doesn't work anymore. thanks a bunch
    Did you reset your ECU?
    If you did, Just let your windows go up and down a few times, then the auto function should come back.
      ahh thanks. i've just found some threads on clubrsx as well, apparently you have to hold down for 5 seconds, then hold up for another 5 seconds, then it should work. will try this tomorrow. cheers.
        there is also a remedy for this problem in the owners manual.
        T U 8 8 Y R - 0 6 5 4 8
          fixed!
            u must've fitted that kpro or motec to cause this problem...
