Final drive for AUDM DC5R
    hi...can someone tell me what's the actual Final drive for AUDM dc5r? since i know that JDM dc5r is 4.78 and USDM dc5s is 4.4.
    i was watching the 'bang for buck for dc5r' and saying that changing higher ratio of final drive such as ATS final drive can gain a torque?
    audm is same as jdm 4.7
      The following link should explain the functioning of a shorter final driver.
      http://www.team-integra.net/sections...?ArticleID=707
      "No Matter that you have a PhD and have read all of Henry James twice. If you still persist in writing, "Good food at it's best", you deserve to be struck by lightning, hacked up on the spot and buried in an unmarked grave" (Truss, 2003, p.44).
        wow,that link has clearly defined everything that i need to know.. thanks BF btw where u get ATS FD and how much for it
          I'd suggest contacting JDMyard as they should be able to give you a quote.
            i hear that the CRV final drive is even lower....
              I think around 1k, but I'm not sure. Speak to your importer of choice.
                CRV even lower??so dc5r or dc2r's FD is the highest stock FD=4.785??how bout S2000, would that be higher ??curious
                  Later model CRV's about 5.06, as is FN2 2007 CTR.
                  I think S2000 is 4.1.
                  You K series guys should drop in some of these 5.X FD's that are around. Nasty!
                  http://www.jasmotorsport.com/transmission.htm
                  http://www.worldvision.com.au http://ww.compassion.com.au
                    go OEM JDM final drive!! its 5.06 and you can pick them up for around $550.... much cheaper than the ATS 5.06 FD
                      wow...that at least 30% cheaper than the ATS, but then will i feel much different between 4.7 and 5.06? and wat people most likely to get in FD??is it 5.06?
                        sorry man... i dont understand wat ur trying to ask???
                            Originally posted by TeMp View Post
                            not true?or got other meanings?
                              i mean the price is at least 30% lower than the ATS and since 5.06 just a bit higher than the 4.75 so is it good enough to just get the OEM CTR's FD or get even more higher
