DC5R camber setup and problems
    Hi,
    I just installed the Whiteline front and rear 24mm adjustable sway bars, along with Carbing front 6 point under brace and 2 point rear, along with front camber adjusting bolts... so i was all ready to get it wheel aligned to start carving it up...
    but i went to get it aligned and i found that the rear right had almost a degree of POSITIVE camber!!!!
    how can i fix this... who makes the parts and how much?
    and for the people out there with stock suspension on their type r, with the Whiteline bars and under-braces, what alignment setups have you found as the best?
    HELP!!
    find/locate the bent or damaged suspension component and replace it.
      A degree is a lot for it to be out. I agree with tinkerbell, something must be busted.
      As for the alignment settings, I am running one pair of camber bolts on my car and I am about to add another pair in the hopes of getting nearly -2 degrees of front camber. I will be heading up to Winton to test these settings out. Will let you know how it goes if you want.
      As far as toe goes I have no idea, was just going to go with whatever the tyre guy suggested, probably zero toe at the front and slight toe in at the rear.
      I am on stock suspension with a JDM rear sway and RE55S tyres.
