Does anyone have experience with these two clutch kits?
I use to run the sports organic but I didn't enjoy the shuddering at times and now I am tempted to try the heavy duty kit since I don't track as often as I should. I was told the heavy duty pedal feel is heavier than the organic, is it true? What are the pro's and con's apart from the price?
Some info I found on the website.
Sports organic (an accurate description)
The drivability will be similar to a regular clutch, however drivers may experience increased pedal effort, slight shudder and increased cabin noise due to the performance characteristics of the clutch. All of our clutch discs have high capacity sprung centre dampers to reduce the drivetrain shock and impact.
Heavy Duty
no info..
Heavy Duty
no info..
![Confused](http://forum.clubitr.com.au/core/images/smilies/confused.png)
