jdm 96spec brake upgrade
    as you might know the brakes on the jdm 96spec typeRs are smaller than the 98specs, i would like to upgrade my brakes to the 98spec ones but keep the 4x114.3 pcd as i have the wheels i want allready.
    spoon make a rotor that is the correct size, offset and stud pattern to use the 98spec brakes but with the caliper do i have to use the 98spec bracket as well as the caliper or i just need the caliper??
    and which spoon front caliper is better(performance wise) the monoblock or the 2 peice??
    Thanks!!
