Squeaky clutch pedal
This topic is closed.
    Hey guys,
    when im creeping forward to park the car, i can here it squeak everytime i push the clutch pedal in nad out, its coming from under/outside the car, cause its very pronounce when in the garage with window down.
    What could it be? how do i fix to stop it squeaking?
    Cheers
    Chosta
    Probably coming from your 'box. Plenty of cars do it. Does your clutch feel any different?
      i had a similar noise but i found it to be the load spring assembly on the firewall pedal box, just greased it up, as it was a bit dry
        http://forum.clubitr.com.au/showthre...t=clutch+pedal
        Next time please do a search! Pm me if you want this thread unlocked.
        "No Matter that you have a PhD and have read all of Henry James twice. If you still persist in writing, "Good food at it's best", you deserve to be struck by lightning, hacked up on the spot and buried in an unmarked grave" (Truss, 2003, p.44).
