Squeeking sound on left turn?!?!!
    was driving today and heard a weird squeeking noise (similar to that of when your brake discs have rust and you brake and makes that squeeking whining sound, just not as high pitched)
    Found that it only makes this noise on moderate to sharp left turn at about 40km/h and over. It also rarely makes the sound when im going in a straight line.
    I have no idea what it could be i know my CV needs to be repaired but dunno if its the the CV thats causing this weird sound.
    All help would be appreciated.
    Do you have a CAI?
    Cos it could be the wheel rubbing up against the pipe.
      no not that my cai goes to mudflap and is not being hit
        Check your wheels bearing.
          maybe it's your suspension?
            Cmon ppl
            There are so many knowledgable ppl on this forum one of you must know something?
            Even if they are just ideas just post so i can check and if its not that i can move onto the next thing.
              maybe ur weighing down the right side and the car can't handle it
                I think i have narrowed it down to Wheel bearing (most likely culprit)
                Im so pissed off atm. Just realised that two of my wheel nuts from the front right wheel the same place where the fuckin sound is coming from are missing.
                so i now need to buy new wheel nuts + CV and Wheel bearing fixed + new spacers with extended studs
                F*&K!!!!!!
                  costly repairs.
                    Good news (thanks for the advice, but it was completly wrong)
                    The clunking noise i had which i throught was the CV ended up being my braided lines lightly hitting my wheel weights on full lock. I started laughing when i found out lol.
                    And my mechanic has eliminated the possibilty of the whining noise being a wheel bearing which im very relieved about. I actually think i figured it out today (think its the rear right brake pad on the wear indicator. Only reason i say this is because when i go around a corner where it would usually make the noise i apply the handbrake just a little and it stops the noise completely)
                    So yeah im happy now.
