Currently i have this setup on my car which runs the torsion beam rear design. Due to the lightness of the rear the car is experiencing alot of sea-sawing effect.
The question i want to ask is. On the damper body the bracket down the bottom is able to be adjusted up-down. Whilst this does not raise or lower the ride height *spacers under the springs do that job* what is the effects and results of me lowering the damper bracket?
Would it make the damper have a longer stroke and hence making it less bumpy overall?
If this is not the effect it would give what would lowering/raising that bracket do overall?
