If so what are the reasons?
is dot 5.1 brake fluid bad for the street?
In my experience anyway Tinker. I am using DOT 5.1, last time I bleed it (it was a good bleed as well as I do it myself with my own method) was only 15,000km ago, and I drive like a granny and haven't tracked my car for almost 1.5 years, my pedals are now a bit soft and I just know there's definitely some air bubbles in my lines.
i thought that dot 5 was not suitable for street use. they use it in tractors and alike. It contains silicone. It compresses more and will give a spongey feel .Dot 5.1 is suitable for street use. I just use castrol super dot 4. which is rated at dot 5.1 specs.Last edited by no_torq; 02-04-07, 04:00 PM.
Originally posted by vtml View Postmy pedals are now a bit soft and I just know there's definitely some air bubbles in my lines.
air does not materialise in brake fluid by magic...
and yes, i have read about your "method" of brake bleeding... and thought: "well, if you are happy, then i won't comment"
but it sounds like you might be unfairly and incorrectly blaming the fluid for your soft pedal...... retired/
I never tried Dot 5 before..
but Dot 5.1 i always though required less bleeding..
i thought it was the temperature rating and price was the difference between Dot 5.1 and dot 4..
I tried the Castrol Super Dot 4.. its quite nice and actually affordable =P
trying out penrite Sins Plus i think its a 5.1 it says rated at 600 degrees ( i assume Fahrenheit?)
Cheaper than Motul.. cant really give much comparison.. but i thought the Penrite had a really firm feel.. and still very firm..
and what Tink said.. air doesnt materialise from nothingness..Last edited by Wlee2; 02-04-07, 04:12 PM.Memorable quotes
Originally posted by Q_ballsome say, his vtec was switched off on his last 4 outings at wakefield....
all we know is hes called The Perry!!Originally posted by tinkerbellif those HA's are 7k old - i will eat my own arsehole...
Originally posted by WayneNever again complain about a honda's reliability just be glad you dont own an Alfa
funnily the dot 5.1 is cheaper? motul 5.1 is $13.50 as compared to rb600.
i read up on the 5.1 and the 5.1 is supposed to be a hybride dot 5 fluid and the main factor is that it is non silicon and will mix well with other dot 3-4-5 fluid for those not doing a completly squeeky clean flush
5.1 is definitly not silicon as a silicon fluid requires the whole braking systems to be taking apart and cleaned out.
Thanks to a link ed gave me i think its partly becuase dot 5 does not absorb air and therefor create airpockets which can corrode the braking system. Where as the dot 3-4 absorbs the air
Originally posted by Jingers View Postfunnily the dot 5.1 is cheaper? motul 5.1 is $13.50 as compared to rb600.
I always thought it was absorbing moisture in the air more than actual air itself..
but could be wrong on that one i only heard it not read it =PMemorable quotes
RBF 600 has better wet boiling point though...
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
http://www.stoptech.com/tech_info/wp...mparison.shtml... retired/
it really comes down to the sort of driving you are looking at...
if you intent to keep the car on the road, a good flush every few years is sufficient enough.
if you intent to track the car, do a complete flush on the eve of the track day but even then, you would need braided lines, slotted rotors and a set of good pads to fully compliment the flush. I know i used to flush my fluid with RBF600 and it held up very well on QR and Darlington
p.s. - braking on public roads is very different to braking on the track_______
:: Foot To The Metal :: Full On :: All of It Or None of It ::
Originally posted by twmwong View PostOh really...I haven't bleed mine for almost 3 years and still works fine & hard
maybe it is because you don't brake hard enough!Last edited by tinkerbell; 03-04-07, 10:18 AM.... retired/
Originally posted by tinkerbell View Postssshhhhssshhh!
maybe it is because we don't brake hard enough
that said, i am going to bleed mine for the first time in 10 months... before eastern creek SS on the 22nd...
brake fade at eastern creek turn 2 is not funMemorable quotes
