DC5 rear toe adjustment
    How can the rear toe be adjusted?
    Do the rear bushings where it bolts to the car have some movement???
    There's an eccentric bolt on the rearmost part of the trailing arm where the lower control arm attaches. The process is basically to loosen the nut, then turn the bolt until desired toe value is achieved
      how odd.. thanks
