Lowering DC5s
    Lowering DC5s
    Hey guys, just bought my dc5s a week ago. Really happy with it, im lowering them with coilovers however i was wondering do i also need to replace the tie rods when i lower the car. If that is the case is there any recommendation on what tie rods should i replace it with. THank you
    You won't need to replace the tie rods when lowering the DC5, unless you needed more toe or camber adjustment then aftermarket tie rods is needed. If this is the case, the best aftermarket tie rods are the modified OEM tie rods known as Todd's tie rods on ClubRSX.
    http://dvrace.com/tierods/
      Thanks for the advice guess i wont be needing one then cheers
