Hello fellow honda enthusiast,
im in need of some help, I am completely stumped and cant figure this out.
two weeks ago i decided i am going to do some maintanence on the car, give it a freshen up as it had oil leaks and needed an oil change. I drove the car into my carport, put it on stands. The car was running very very strong and had no problem at all.
I then changed the following
rocker cover gasket
spark plug tube seals
and all the little seals for the nuts on the rocker cover
camshaft plug (near the vtec solenoid)
vtec solenoid seal
dizzy o ring
sump gasket
and gave an oil change
since putting it back together, I cant get it to start, it cranks and cranks but doesnt catch. this is a short video i have done https://www.youtube.com/watch?v=2LKF...be&app=desktop
so what i have checked is for
- spark - i have got this confirmed it by putting a plug at the end of the lead and turning the motor, even changed the coil just in case and the dizzy is in right..
- fuel - i have fuel you can smell it on the plug, checked fuel pressure as i have that, and also checked fuel injector pulse and i have that aswell, fuel pump primes aswell.
- immobiliser - i had the old one taken out as i thought it might be that and it wasnt that aswell, taken out by a professional
- electrical plugs - i only removed dizzy plug, vtec solenoid plug, and o2 sensor plug on the down pipe when i had to change the sump. all are plugged in.
can you guys please help me, i have no idea, some people are saying it could be compression or the cam timing could be wrong but i dont know how this happens if i only changed seals didnt touch the cam belt nor the head. I have never ever had a car that i just done seals on not to start.
rocker cover gasket
vtec solenoid seal
dizzy o ring
sump gasket
