Hi!
I'm in need of help, I've recently had a gearbox overhaul and new clutch installed. I adjusted the clutch as on first start up the Clutch wasn't fully engaging. After 2 days of driving the Clutch pedal was slowly getting more free play. By the time I got to my destination the pedal was gone with no pressure. I opened up the reservoir to find no fluid. So I've gone searching for a leak and found that the slave cylinder on the gear box was loose. I've tighten the clutch line nut but the (locking nut?) won't tighten. Just want to make sure that is how it is suppose to be?
Sorry for me horrible way of explaining this
Thanks for any help !!
