EP3 coilovers into DC5
    Hey guys,
    I've utilised the search bar and can't find any info on this forum. To broaden the options available for aftermarket coilovers, how does fitting coilovers made for an EP3 into a DC5R look. I know you'll need EP3 Tie Rod ends, but what else? I guess basically what parts would you need to make it seamless and would any of you recommend it?
    Thanks!
    I think you'll find there is a difference in the size of bottom bush in the rears, one is smaller than the other, can't remember which way it goes though sorry
    Sent from snoopnugs ringer
    using Tapatalk
      Im running EP3R RSD in my DC5.
      Front tie rod ends must be changed to EP3.
      Rear coilover bushes can be spaced with a washer or replace the bushes (I ended up doing both).
      Never had a problem with it
      hope this helps
