Lately something i've noticed with the rear hatch is that the actuator is playing up, especially in the heat. Is this a common issues? Is there a simple fix or do we just replace the actuator?
DC5R rear boot issues
It's a fairly common issue, go through the workshop manual procedure to check the wiring and confirm it's the actuator. Once confirmed just replace the actuator, should be able to order it from Amayama or the US for the best price. Manuals can be found here: http://www.hondahookup.com/manuals/.
Theres a cheaper way of fixing it rather than replacing it. Pull it apart and swap the motor inside.
Have a read here:
OK anyone who has had/is having problems with this automatic electric switch for opening your rear hatch. Accura will tell you you have to replace the actuator assembly (aprx $125 canadian). Despite the obvious poor performance of the part (as seen by the many people previously posting with this problem), accura's engineering department continues to install this system! I don't even own this car but my friend does and having just helped her out after speaking to the bigest a**hole I've ever heard from at the dealership (they wanted to charge her $600 to replace the lock and actuator) I've decided that this is nothing but a disgusting cash grab!!!!!! So here's the $2 fix. If any of you have a tech website feel free to post this fix on it as I will not be posting it anywhere else and it will otherwise disappear after 7 days. If you've never had this problem you may want to print this for when it will enevitably happen.
I have solved the problem with the trunk release actuator (don't give accura a penny before reading this).
Beginers start here:
1) remove plastic liner at rear of trunk (unscrew both bolts & remove the plastic button like things with the help of a needle to pry the center part out)
2) Looking out from the inside of your trunk you will see a black plastic box (6"length) to the lower right of the trunk latch, this is the actuator assembly, your goal is to remove this part.
3) Unclip the bar ataching the actuator to the lock mechanism (lower left of the trunk latch)
4) Undo the three brass bolts attaching the bracket which holds the actuator assembly.
5) Unscrew and gently remove the black actuator assembly (4 brass screws securing it to the bracket , then 4 more holding the part together, you can't tell which is which so just be carefull the thing doesn't open up and spill the parts out)
6) bring the part in to your workbench to work on the part.
7) You will most likely want to reconect the bracket and rod from #3 & 4 above, now your trunk will still work perfectly with the key untill you're ready to replace the fixed actuator.
Advanced start here:
6) remove the cover of the actuator assembly, you will now see two sets of sprockets and a motor in the lower portion.
7) remove sprockets slowly to get at the motor.
8) remove motor by gently tuging straight up ( don't lose the little white stabiliser bit on the end).
The motor is a $5 canadian (that's like 50cents US Click the image to open in full size. ) part produced by Mabuchi motors for all kinds of small aplications like high school science experiments. Accura engineers have simply added a special gear on the end of it which is welded on and you shouldn't waste your time trying to remove.
There is no serial number on the motor (VN... is the manufacture date). And you cannot order a replacement motor with the gear on it but you can get the motor without the gear. From the note in the package I received it looks like the serial # should be FC 280 PT - 20150.
http://www.mabuchi-motor.co.jp...0pasa
The motor is likely fine and just need to be cleaned or the small plastic end cap needs replacement.
9) use a small pair of needle nose pliers and a baby screwdriver to very gently pry off the 2 crimps and then the plastic end cap. This took me 30 minutes to and hour just be patient and carefull not to stab yourself with the screwdriver.
10) Once you get the endcap offdust off the interior of the motor with a cloth and maybe some rubbing alcohol if you want.
11)Replace the plastic cap with a new one from mabuchi. Be carefull to ensure the brushes (2 tiny metal looking blocks slip over the spindle)
12) Replace white plastic endcap on the motor and replace the motor in the black case.
13) replace sprockets, close black case and screw in the four short brass screws.
14) plug assembly back into car and verify the trigger moves when you slide the switch on your trunk (make sure it's unlocked from the drivers side first).
15) If it works reinstall in reverse order of removal proceedures above.
Well I hope this helped some of you, please post if it did, or didn't and like I said someone please repost this permanently somewhere out there. I would hate to have waisted my time typing this out for nothing. Best of luck everyone!
The website for Mabuchi motors in Japan & US is:
http://www.mabuchi-motor.co.jp....html
Unlike the experience I had with Accura these people are absolutely fantastic and most helpfull. The part you want is: FC 280 PT-20150 and preferably just the plastic end with the brushes (else you'll have to pry it open again).
As an afterthought if you found this helpfull and it saved you some dough, please buy a new toy to donate for christmas, or make a small donation to the next charity you see (and no, a pledge to Bush doesn't count).
Cheers, L
**Enjoy and good luck..Hope you sort out your issue..Any questions, Pm me
FD3S Questions? Pm me.
