Hey guys, I have recently installed a Vision rear camber kit, Spoon rear tie bar and Cusco rear sway bar (25mm) on my TypeS and got a wheel alignment done, and my specs are as follows
front left camber: -1deg 08'
toe: +0.4mm
front right camber: -1deg 07'
toe: +0.2mm
rear left camber: -3deg 07'
toe: +2.1mm
rear right camber: -2deg 05'
toe: +1.9mm
I'm fine with the front settings, maybe just half a -ve degree more front camber, but I think the rear should have less camber and less toe. The guys said they honestly didn't know the rear camber was adjustable and didn't know I had a rear camber kit. They suggested to run -1deg 05' rear camber, which sounds about right, but what are your thoughts?
What would be your expert suggestions on what settings to run?
toe: +0.4mm
toe: +0.2mm
toe: +2.1mm
toe: +1.9mm
