this is for dc2r:
i am running zeal function xs coilovers with 12kg/mm / 8kg/mm springs, vision front and rear camber kits with following alignment settings:
camber: 2.4deg (ront) / 1.3deg (rear)
toe: 1minute toe out on each side (front) / 10minutes toe in each side (rear)
i recently changed my settings, reduceing the front toe out from 6minutes to 1minute each side in an attempt to reduce excessive inside tyre wear.
the other thing i changed was reducing rear ride height by 3mm. before the change i was very happy with the setup of the car, handling was great. it did have a tendancy for slight light feeling at the rear when pushed too hard, and for example the back came out twice on the last track day when i entered a corner too fast, with the weight transfer off the rear wheels the back spun out. so i had been toying with the idea for a while to slightly lower the rear and my thoughts were that this would give the car a more neutral-to slight understeer feel at the limit.
so i took the car for a drive recently and found that the back still has that feeling, if not slightly more.. what is the reason for this? does the rear suspension lack stroke?
at the same time as the setting change i also got new tyres, replacing the YH ES100's with DL sport maxx's. at 1st i thought maybe the tyres were the cause but on further acquaintance the tyres seem to be of a very similar grip level to the yokohamas..
any suggestions /advice?
i think i need to wait for the weather to cool down and get used to the car again..
