Can't even find something to replace the amber turn lights in there, anyone else find something like this ? If I end up purchasing this I want them out!
Amber lighting inside JDM DC2 headlights - u wot m8
Looks like the lens itself is tinted, so I'd expect the only way to correct it would be to remove the outer lens (typical oven method to soften the adhesive), then the inner amber lens and replace it with one from a donor headlight.
BTW please don't butcher a perfectly good DC2R and make it unroadworthy.
Originally posted by ChargeR View PostLooks like the lens itself is tinted, so I'd expect the only way to correct it would be to remove the outer lens (typical oven method to soften the adhesive), then the inner amber lens and replace it with one from a donor headlight.
