HELP: Idle goes up and down after not starting up for 2 weeks
    Just came back from a 2 week holiday and decided to give my car a spin today. For some reason, when i stopped at a traffic light, the idle of the car keeps jumping from 3000 RPM down to 1500 RPM. its continuous until i take off but reoccurs when the car is stationary.
    How can I fix this?
    What car is this?
    What mods do you have on the car?
    Is it tuned?
      Originally posted by butter View Post
      What car is this?
      Is it tuned?
      EP3R
      mods: CAI, full cat back exhaust with headers.
      Car isn't tuned. full standard ECU
        Maybe try clean your IACV (idle air control valve) using throttle body/brake cleaner/degreaser.
          +1
          The IACV might be sticking, causing erractic idle
            It could also be a vacuum leak. Had the same issue recently and found that the vacuum hose for one of the emisssions assist valves had come off.
              Originally posted by iVTEC_R View Post
              +1
              9 times out of 10 it's this. The IACV tends to seize up if not used.
              CW DC5R Build
                thanks for the input guys. Well I've been driving the car for 2 days now and the problem is gone now.
